Group bus instance limiting for continuously playing events
We have a lot of vehicles with (different) engines that are constantly running events, and I think this may be what is causing Stuttering after upgrading 2.01 to 2.03. What I want is effectively bus instance limiting with virtualisation, but I know that this isn’t possible, I can see there are a couple of other forum posts about it.
Instance limiting using furthest etc actually stops the events, which for continuously running events isn’t desirable.
The best workaround I can think of is to implement event instance limiting ourselves - periodically calculate the distance of each vehicle from the listener, and make sure that the N closest (where listener distance < event max distance) are playing, and all others are stopped. Is this what you’d advise? Are there any gotchas about it? Apart from it being a bummer that I need to write some finicky code, the events also don’t start warm… but I don’t think that this matters to us. E.g. no parameters with velocity.
