How to adjust the speed of the audio without changing the pitch?
I noticed in the documentation it says:
It is recommended you follow along with our examples found in api/core/examples/plugins as they are fully implemented working effects you can use or base your code on.
But I didn’t find exactly what this relative path refers to, can you explain what it means?
Ok, after some searching I found it: Where is the plugin example code?
