How to drag onto automation widget?
From the latest release-notes: “Parameters can now be dragged and dropped into an automation widget to add automation curves. Multi-select is supported.”
Perhaps I’m blind but I can’t figure out how to do that, or what even is the automation widget - any clearer instructions available on that? :slight_smile:
The automation widget is that box that appears in the deck when you’ve added automation to a property. You can drag parameters onto this widget from the parameters browser.
