Hi everybody,
I’m again having issues trying to reduce music volume during voice. Every year again. And every time the solution I wrote down does not work anymore. I really feel stupid now.
What I wan to do is: I have a programmer instrument which plays voice, and as long as it is playing, I want to reduce music. This works fine for my existing projects, but I cannot get it running for a new project.
This is my timeline:
m
The steps that previously worked were:
- Add a parameter „VO Sidechain“ in the preset browser (all default settings)
- Add a parameter sheet for „VO Sidechain“ so I can actually select the parameter later on
- On the Voiceover track, add a Sidechain effect
- Right-click on the sidechain effect (not on the volume knob) and select „Connect to Modulator“, then connect it to „VO Sidechain“ (from my understanding, this will cause the sidechain to send the volume to the VO Sidechain parameter, modifying its value)
- In the preset browser, modify the parameter threshold to span everything, and set Amount to 1 (otherwise setting the condition later on is hard)
- On the loop region, add the „VO Sidechain“ parameter as condition
Now, step 4 fails because Connect to Modulator is greyed out. And I’m stuck. ![]()
There is also the possibility to right-click on the Fader knob and then „Add Modulation“, but this is the other way round – the parameter value is used as input and controls the knob. I want the volume to control the parameter value.
Thanks for your help!
Simon
PS: And, thanks for FMOD ![]()
