Hi there,
I’m building a virtual mixing desk for the web browser using the FMOD HTML5 API, but I’m having some issues with audio stuttering.
It seems that calling gSystem.update() in a JS setInterval is causing thread queueing issues as the UI gets more complex. As I’m adding things like level meters, pan pots and faders, my setInterval is being queued behind UI updates, which is causing FMOD to stutter because it interrupts the game loop.
I’m aware that JS in the browser is single threaded, and there may be no answer to this other than “make the UI simpler”, but I wanted to double check that there wasn’t a way to run the FMOD game loop on a different thread from the UI. Will FMOD run in a web worker? Is there something I can do around audio worklets? I only need to target the latest browsers so compatibility isn’t an issue.
Thanks in advance for any advice.
