I want to move a project to a new computer, but Fmod isnt saving the audio files
I want to move a project to a new computer, but Fmod isnt saving the audio files.
Everything is intact, except for the actual audio files.
I’m using Fmod version 1.08.01.
A friend of mine has the same problem on another project, another computer, using the same version. Any ideas how I can make a copy of the project without loosing the audio files? Thanks!
I found a solution.
I had put in a custom directory in the Asset Folders preference.
What I did to reset was to manually import the audio file folder hierarchy into the new projects Asset folder, and then I removed the custom directory from my Asset Folder Preference.
Thanks.
Hi Zid,
When you say you’re trying to move a project, how are you doing this?
If you select File > Package Project, you need to ensure that “Audio Assets” to ensure the audio files are being included in this.
Thanks,
Richard
I can’t see any “Package Project”. But I found out the solution myself:
I had entered a custom directory in the Asset Folders preference. I simply deleted the custom directory and the project copied over the save files as normal.
Thank you anyway!
