Hi! I have a problem, I need the wind event , while the player is in the room, slightly muted by eq. I thought I could do it using snapshot , but I can’t figure out how I can call a snapshot for just one event or group.
Hope u guys canb help me
- In the mixer window, select the snapshot.
- Right-click on the property you want to be affected by the snapshot (in your case, the volume slider of the group bus into which the wind event is routed) and select “Scope In” from the context menu. This adds the property to the snapshot’s scope.
- Set the property to the value you would like it to have while the snapshot is active.
Snapshots only affect the specific properties that have been added to their scope, and do not affect other properties at all. Therefore, if you want a snapshot that only affects the volume of one group bus, you must scope only that group bus’ volume in to the snapshot.
joseph u always help so much, thanks again u awesome!!!
