Current version 2.01.03
The setup for the event:
- The event has several multi instruments
- A global discrete parameter controls a local discrete parameter
- Local parameter has “hold on playback” enabled
- Local parameter is automated by global at 1:1 values (range is 0 to 23)
- Each multi instrument has playback conditions set from the local parameter
All values play the instrument with the corresponding condition, apart from the instrument conditions for 14 and 15, changing the conditions to any other value works and changing other instruments to 14 or 15 stops them too.
What could be causing this?
