Hi guys,
Sound is continue while ios mute switch is enabled. Do you know what should be the problem?
unity vers : 2021.3.21f1
fmod vers: 2.02.09
Hi guys,
fmod vers: 2.02.09
Have you set an AVAudioSession category yourself? Or are you just using the default category/haven’t messed with any AVAudioSession settings at all?
we are using default category.
Unfortunately, I’ve been unable to reproduce the behavior you’re describing - the mute switch successfully mutes FMOD audio without any issues. If possible, could I get you to upload your Unity/XCode project to the “Uploads” tab of your FMOD User Profile so that I can reproduce and hopefully diagnose the issue? Also, what iOS device and iOS version are you using?
