No audio in iOS build but no errors (works fine in editor and macOS build)
I’m getting no sound from my iOS build once I run it in xcode (have tried on my iphone and ipad). The sound works fine in the Unity Editor and worked great in my macOS build. I enabled the FMOD Studio Debug and it appears to be registering the audio as running (volume is moving around appropriately), so it seems like the banks are loading, but nothing makes it’s way to the speakers. I have a mixerResume() at the beginning of each scene. I’ve also played around with different file types (PCM, Orbis etc) but nothing. I’m also fully up to date with Unity, Visual Studio and FMOD Unify verified releases. Any ideas? Anything else that I’m missing in the set up?
Maybe try calling FMODUnity.RuntimeManager.CoreSystem.mixerPause() first and then call FMODUnity.RuntimeManager.CoreSystem.mixerResume().
If that doesn’t work, can you please enable logging in the FMOD Unity settings and send through any logging information you are getting from XCode?
An XCode, FMOD and Unity version would be helpful too!
I had exactly the same problem, only on IOS14, only when Unity audio was disabled, and when trying to play a sound while displaying a video. This mixer Suspend/Resume trick worked for me
Good to hear, thanks for letting us know!
Thanks for the repies! It took me a while to figure out how to get the logging in Xcode (new to a lot of this). I’m using Unity 2021.1.16f1, FMOD 2.01.09 and Xcode 12.5.1. Here’s what I’m getting from the logging (apologies in advance - this is long!):
FMODUnity.RuntimeManager:DEBUG_CALLBACK(DEBUG_FLAGS, IntPtr, Int32, IntPtr, IntPtr) (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/RuntimeManager.cs:45)
FMOD.Studio.System:create(System&) (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/wrapper/fmod_studio.cs:387)
FMODUnity.RuntimeManager:Initialize() (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/RuntimeManager.cs:235)
FMODUnity.RuntimeManager:get_Instance() (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/RuntimeManager.cs:102)
FMODUnity.RuntimeManager:get_StudioSystem() (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/RuntimeManager.cs:125)
FMODUnity.RuntimeManager:AddListener(StudioListener) (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/RuntimeManager.cs:398)
FMODUnity.StudioListener:OnEnable() (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/StudioListener.cs:20)
[FMOD] SystemI::setOutputInternal : Setting output to ‘FMOD Core Audio Output’
UnityEngine.DebugLogHandler:LogFormat(LogType, Object, String, Object[])
UnityEngine.Logger:Log(LogType, Object)
UnityEngine.Debug:Log(Object)
FMOD.System:setOutput(OUTPUTTYPE) (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/wrapper/fmod.cs:950)
FMODUnity.RuntimeManager:Initialize() (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/RuntimeManager.cs:241)
[FMOD] Manager::init : maxchannels = 128 studioflags = 00000008 flags 00000000 extradriverdata 0x0.
FMOD.Studio.System:initialize(Int32, INITFLAGS, INITFLAGS, IntPtr) (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/wrapper/fmod_studio.cs:412)
FMODUnity.RuntimeManager:Initialize() (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/RuntimeManager.cs:287)
[FMOD] SystemI::init : Initialize version=20109 (115889), maxchannels=128, flags=0x00020000
[FMOD] OutputCoreAudio::init : Hardware buffer size: 1024 samples, hardware sample rate: 48000Hz, hardware channels: 2
[FMOD] OutputCoreAudio::init : Maximum hardware read size: 4096 samples, Software buffer size: 512 samples, Number of software buffers: 4.
[FMOD] OutputCoreAudio::init : DSP buffer size * DSP num buffers is potentially too small.
UnityEngine.Debug:LogWarning(Object)
FMODUnity.RuntimeManager:DEBUG_CALLBACK(DEBUG_FLAGS, IntPtr, Int32, IntPtr, IntPtr) (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/RuntimeManager.cs:41)
[FMOD] Thread::initThread : Init FMOD stream thread. Affinity: 0x8000000000000003, Priority: 0xFFFF7FFB, Stack Size: 98304, Semaphore: No, Sleep Time: 10, Looping: Yes.
[FMOD] SystemI::DSPCodecPoolRegister : register codec pool for pool type 7
[FMOD] Thread::initThread : Init FMOD mixer thread. Affinity: 0x8000000000000001, Priority: 0xFFFF7FFA, Stack Size: 81920, Semaphore: Yes, Sleep Time: 0, Looping: Yes.
[FMOD] AsyncManager::init : manager 0x10f882e08 isAsync 1 updatePeriod 0.02
[FMOD] Thread::initThread : Init FMOD Studio update thread. Affinity: 0x8000000000000002, Priority: 0xFFFF7FFD, Stack Size: 98304, Semaphore: No, Sleep Time: 1, Looping: No.
[FMOD] AsyncManager::init : done
[FMOD] PlaybackSystem::init :
[FMOD] Thread::initThread : Init FMOD Studio sample load thread. Affinity: 0x8000000000000003, Priority: 0xFFFF7FFD, Stack Size: 98304, Semaphore: No, Sleep Time: 1, Looping: No.
[FMOD] PlaybackSystem::init : done
[FMOD] Thread::initThread : Init FMOD Studio bank load thread. Affinity: 0x8000000000000003, Priority: 0xFFFF7FFD, Stack Size: 98304, Semaphore: No, Sleep Time: 1, Looping: No.
[FMOD] Manager::init : done.
[FMOD] Manager::readBank : fileversion = 135, compatVersion = 132 (oldest = 44, newest = 135)
[FMOD] PlaybackSystem::acquireMasterBus : Setting master channel group format to 3
[FMOD] SystemI::mixerSuspend : Suspending output.
FMOD.System:mixerSuspend() (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/wrapper/fmod.cs:1180)
Begin:Start() (at /Users/username/FOLDER/GameName/Assets/Scripts/Begin.cs:21)
Suspended Begin
Begin:Start() (at /Users/username/FOLDER/GameName/Assets/Scripts/Begin.cs:22)
[FMOD] SystemI::mixerResume : Resuming output.
FMOD.System:mixerResume() (at /Users/username/FOLDER/GameName/Assets/Plugins/FMOD/src/Runtime/wrapper/fmod.cs:1184)
Begin:Start() (at /Users/username/FOLDER/GameName/Assets/Scripts/Begin.cs:23)
PlayerMovement:ResumeAudio() (at /Users/username/FOLDER/GameName/Assets/Scripts/PlayerMovement.cs:46)
PlayerMovement:Start() (at /Users/username/FOLDER/GameName/Assets/Scripts/PlayerMovement.cs:35)
PlayerMovement:ResumeAudio() (at /Users/username/FOLDER/GameName/Assets/Scripts/PlayerMovement.cs:48)
[FMOD] SystemI::createSound : filename = /private/var/containers/Bundle/Application/DCC8025B-89BF-47D4-97CE-BA4737578AB1/Music.app/Data/Raw/Music 15 Vln.streams.bank : mode 02010082
[FMOD] SystemI::createSound : FMOD_NONBLOCKING specified. Putting into queue to be opened asynchronously!
[FMOD] Thread::initThread : Init FMOD nonblocking thread (0). Affinity: 0x8000000000000003, Priority: 0xFFFF7FFC, Stack Size: 114688, Semaphore: Yes, Sleep Time: 0, Looping: Yes.
[FMOD] SystemI::createSound : setdata soundi = 0x1185d0df8 : node = 0x1185d0fb0
[FMOD] SystemI::createSound : add node to async list : head = 0x1185d1228. list count = 0
[FMOD] AsyncThread::threadFunc : Starting Asynchronous operation on sound 0x1185d0df8
[FMOD] SystemI::createSoundInternal : Create name=’/private/var/containers/Bundle/Application/DCC8025B-89BF-47D4-97CE-BA4737578AB1/Music.app/Data/Raw/Music 15 Vln.streams.bank’, mode=0x02010082
[FMOD] SystemI::createSound : setdata soundi = 0x1185d2ef8 : node = 0x1185d30b0
[FMOD] SystemI::createSoundInternal : exinfo->cbsize = 224
[FMOD] SystemI::createSound : setdata soundi = 0x1175b5f48 : node = 0x1175b6100
[FMOD] SystemI::createSound : add node to async list : head = 0x1185d1228. list count = 1
[FMOD] SystemI::createSoundInternal : exinfo->length = 14810208
[FMOD] SystemI::createSoundInternal : exinfo->fileoffset = 832
[FMOD] SystemI::createSound : setdata soundi = 0x1175b7f78 : node = 0x1175b8130
[FMOD] SystemI::createSound : add node to async list : head = 0x1185d1228. list count = 2
[FMOD] SystemI::createSoundInternal : exinfo->numsubsounds = 1
[FMOD] SystemI::createSoundInternal : exinfo->inclusionlist = 0x1185d10c0
[FMOD] SystemI::createSound : setdata soundi = 0x1185d31d8 : node = 0x1185d3390
[FMOD] SystemI::createSoundInternal : exinfo->inclusionlistnum = 1
[FMOD] SystemI::createSound : add node to async list : head = 0x1185d1228. list count = 3
[FMOD] SystemI::createSoundInternal : exinfo->suggestedsoundtype = 5
[FMOD] SystemI::createSoundInternal : exinfo->initialseekpostype = 1
[FMOD] SystemI::createSound : setdata soundi = 0x1185d4c18 : node = 0x1185d4dd0
[FMOD] SystemI::createSound : add node to async list : head = 0x1185d1228. list count = 4
[FMOD] SystemI::createSound : setdata soundi = 0x1185d65d8 : node = 0x1185d6790
[FMOD] SystemI::createSound : add node to async list : head = 0x1185d1228. list count = 5
[FMOD] SystemI::createSoundInternal : Stream 0/1: name=‘VLN 4 Music 15’, format=5, channels=2, frequency=48000, lengthbytes=2149600, lengthpcm=14690304, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.304138.
[FMOD] Thread::initThread : Init FMOD file thread. Affinity: 0x8000000000000003, Priority: 0xFFFF7FFC, Stack Size: 49152, Semaphore: No, Sleep Time: 10, Looping: Yes.
[FMOD] AsyncThread::threadFunc : Finished Asynchronous operation on sound 0x1185d0df8
[FMOD] AsyncThread::threadFunc : Starting Asynchronous operation on sound 0x1185d2ef8
[FMOD] SystemI::createSoundInternal : exinfo->inclusionlist = 0x1185d31c0
[FMOD] SystemI::createSoundInternal : Stream 0/1: name=‘VLN 2 Music 15’, format=5, channels=2, frequency=48000, lengthbytes=2430496, lengthpcm=14690304, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.329651.
[FMOD] AsyncThread::threadFunc : Finished Asynchronous operation on sound 0x1185d2ef8
[FMOD] AsyncThread::threadFunc : Starting Asynchronous operation on sound 0x1175b5f48
[FMOD] SystemI::createSoundInternal : exinfo->inclusionlist = 0x1175b6210
[FMOD] SystemI::createSoundInternal : Stream 0/1: name=‘VLN 3 Music 15’, format=5, channels=2, frequency=48000, lengthbytes=2578688, lengthpcm=14690304, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.299530.
[FMOD] AsyncThread::threadFunc : Finished Asynchronous operation on sound 0x1175b5f48
[FMOD] AsyncThread::threadFunc : Starting Asynchronous operation on sound 0x1175b7f78
[FMOD] SystemI::createSoundInternal : exinfo->inclusionlist = 0x1175b8240
[FMOD] SystemI::createSoundInternal : Stream 0/1: name=‘VLN 1 Music 15’, format=5, channels=2, frequency=48000, lengthbytes=3382880, lengthpcm=14690304, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.419159.
[FMOD] AsyncThread::threadFunc : Finished Asynchronous operation on sound 0x1175b7f78
[FMOD] AsyncThread::threadFunc : Starting Asynchronous operation on sound 0x1185d31d8
[FMOD] SystemI::createSoundInternal : exinfo->inclusionlist = 0x1185d34a0
[FMOD] SystemI::createSoundInternal : Stream 0/1: name=‘VLN FX Music 15’, format=5, channels=2, frequency=48000, lengthbytes=4256000, lengthpcm=14690304, pcmblocksize=0, loopstart=0, loopend=0, mode=0x00000000, channelmask=0x00000000, channelorder=0, peakvolume=0.341644.
[FMOD] AsyncThread::threadFunc : Finished Asynchronous operation on sound 0x1185d31d8
[FMOD] AsyncThread::threadFunc : Starting Asynchronous operation on sound 0x1185d4c18
[FMOD] SystemI::createSoundInternal : exinfo->inclusionlist = 0x1185d4ee0
[FMOD] AsyncThread::threadFunc : Finished Asynchronous operation on sound 0x1185d4c18
[FMOD] AsyncThread::threadFunc : Starting Asynchronous operation on sound 0x1185d65d8
[FMOD] SystemI::createSoundInternal : exinfo->inclusionlist = 0x1185d68a0
[FMOD] AsyncThread::threadFunc : Finished Asynchronous operation on sound 0x1185d65d8
Nothing jumps out at me from the log and I can see mixerPause and mixerResume are both being called. Can you please double check you have disabled Unity’s built in audio in Unity’s Audio Settings?
Otherwise, I think I am going to need a reproduction from you so I can debug on my end- would it be possible to provide an FMOD and Unity project that reproduces the issue? There is a section in your profile for uploading repros.
Thanks Jeff. Yep, I’ve had Unity’s Audio Settings disabled throughout, but even tried a build with it enabled just to see if it changed anything! The weird thing is that in the FMODs debug pane it appears that the audio is running (volume going up and down), but I still don’t hear anything. I’m sure I’m missing something very obvious/stupid but have tried everything I can think of and as I say, it works well in the macOS build. I’ll look into uploading the repro today - much appreciated!
@jeff_fmod @furfacsake
I have the exact same issue right now with Unity 2021.1.5f1 and FMOD 2.01.11 and I sort of have a clue what is going on.
When you disable Unity Audio, Unity still messes with AVAudioSession in UnityAppController.mm
- (void)startUnity:(UIApplication*)application
    NSAssert(_unityAppReady == NO, @"[UnityAppController startUnity:] called after Unity has been initialized");
    UnityInitApplicationGraphics();
    // we make sure that first level gets correct display list and orientation
    [[DisplayManager Instance] updateDisplayListCacheInUnity];
    UnityLoadApplication();
    Profiler_InitProfiler();
    [self showGameUI];
    [self createDisplayLink];
    UnitySetPlayerFocus(1);
    AVAudioSession* audioSession = [AVAudioSession sharedInstance];
    [audioSession setActive: (UnityShouldActivateAVAudioSession() == 1) error: nil];
    [audioSession addObserver: self forKeyPath: @"outputVolume" options: 0 context: nil];
    UnityUpdateMuteState([audioSession outputVolume] < 0.01f ? 1 : 0);
#if UNITY_REPLAY_KIT_AVAILABLE
    void InitUnityReplayKit();  // Classes/Unity/UnityReplayKit.mm
#endif
Once I remove
FMOD Audio output works fine.
This was noted by another dev as a unity bug here as well:
https://forum.unity.com/threads/avaudiosession-still-initialized-even-if-unity-audio-is-disabled.1089340/
Maybe the FMOD team has better connection to some of the Unity Audio guys to verify this.
@tinytouchtales It does look like there is potential for UnityAppController.mm and platform_ios.mm to have conflicting ideas about whether the sharedInstance should be active or not. If you happen to have time to upload a reproduction then I’d be keen to take a look and see what’s going on in more detail- thanks for sharing your solution!
Hi Jeff, I’ve uploaded it to my account just now. The above solution still didn’t work for me. Thanks again for your help with this.
Thanks for that! Unfortunately I couldn’t reproduce the error by just using your Unity project, would you mind also sharing your FMOD Studio project? Feel free to strip it down, I just need one or two events just to get a more complete picture of your setup!
Thanks Jeff! I’ve uploaded the studio project now. One potential issue that i thought of was that I tried to implement the project using Wwise before switching to FMOD. I’m fairly certain that I’ve cleared all traces of wwise from the project, but do you think that this could be causing it?
So I think I FINALLY figured it out. After reading about audio issues with other apps (that aren’t implementing FMOD) I found a glitch where the ‘silent mode’ switch on the iphone must be switched to it’s ON position in order for the audio to come through! Can’t believe it’s taken me this long to figure it out…!
Aha, yep that explains it! Glad to hear it’s working now, thanks for letting us know!
