One of my students encountered a weird issue with transition regions that I’m not even sure if it’s a bug or not.
He wanted to have quantized transitions to different markers for the first part and the end of a loop.
Both transitions have the same parameter condition (0=no transition, 1=transition) and are quantized every 1 bar.
If the transition is triggered between bar 7-8 it won’t move to marker “PartB”, but it’ll skip the last quantization point and only consider the first one of the next transition region, therefore moving to “PartB2” instead. The same happens with the second region: if it’s triggered between 8-9 the last quantization point is ignored, then loops back to the beginning and triggers the first transition region instead.
But if I extend the length of both transition region by a small amount like this:
it seems to be enough for FMOD to “recognize” the quantization point and move on.
Is this the transition region normal behaviour?
