No FMOD platform found for build target when building using batchMode and -activeBuildProfile
So this is a fun one. Unity 6000.6.0, FMOD 2.03.14
We have some build profiles:
Windows64,
Switch2
The Editor is set to Windows64 build profile.
We want to build the Switch2 platform in batchMode using -activeBuildProfile “SomeProfile.asset”
After adding some logs into FMOD, I noticed that UNITY_SWITCH2 is not defined at the point platform build targets are registered.
For example:
RuntimeUtils.BuildLog($"Active Build Target: {EditorUserBuildSettings.activeBuildTarget}", LogType.Log);
RuntimeUtils.BuildLog($"Active Build Profile: {UnityEditor.Build.Profile.BuildProfile.GetActiveBuildProfile()?.name}", LogType.Log);
#if UNITY_SWITCH2
RuntimeUtils.BuildLog("UNITY_SWITCH2 IS DEFINED", LogType.Log);
#else
RuntimeUtils.BuildLog("UNITY_SWITCH2 IS NOT DEFINED", LogType.Error);
#endif
Results in these logs:
[FMOD Build] Active Build Target: Switch2
[FMOD Build] Active Build Profile: NintendoSwitch
[FMOD Build] UNITY_SWITCH2 IS NOT DEFINED
And looking at the PlatformSwitch2 impl:
internal override IEnumerable<BuildTarget> GetBuildTargets()
    #if UNITY_SWITCH2
    yield return BuildTarget.Switch2;
    #elif UNITY_OUNCE
    yield return BuildTarget.Ounce;
    #else
    yield return BuildTarget.NoTarget;
    #endif
Means that the Switch2 platform is not registered and the build fails with:
BuildFailedException: No FMOD platform found for build target Switch2. You may need to install a platform specific integration package from https://www.fmod.com/download.
Seems like PlatformSwitch2 could just return BuildTarget.Switch2?
Thanks for reporting!
Support for Unity 6.6 is currently planned for FMOD 2.03.16. You can find more information about the currently supported Unity versions.
We also recently released FMOD 2.04, and I tested the same workflow with 2.04 and couldn’t reproduce the issue. If you are looking for a potential workaround in the meantime, you could try updating to 2.04 and let us know if you still encounter the issue.
Thanks. Tested in latest version of Unity 6 (6000.6.6) and the issue does not occur.
