Occlusion in UE4
Is it possible to use the in-built occlusion system with event instances somehow? The documentation covers only component usage. FMOD 2.1.05 UE4
Thanks in advance,
Zsombor
No, it is not possible.
As you have observed, FMOD’s geometry occlusion system is designed for use with components that can be created while using the FMOD Core API. It is not designed for use with FMOD Studio events.
