Open Source?
(Nathaniel Stevens) #1
I’m trying to use the FMOD_StudioEventEmitter rather than having to maintain my own emitter. However, I’ve run into a problem with needing access to the EventInstance in order to register for callbacks. But, of course, it’s set to private. Obviously I can change the FMOD’s code and make the field public but I can see that getting confusing as time passes and updates come out.
I wanted to suggest a getter but was unable to find an open source repository. Is there one available?
Or does anyone know of a better of getting an EventInstance with only the public data from the EventEmitter?
(Nicholas Wilcox) #2
We may look at putting the code up on GitHub in the future.
(Andrew Scott) #3
It’s up on github now :
