Hi, I am seeing an issue with use of integrated Source Control.
Using Perforce (Legacy) when I search my Perforce Depot FMOD is finding 2 projects when there is only one project located in the Server Depot and locally.
Can anyone help me diagnose how this has occurred and how to clear the non existent project from populating in the fmod search list.
Hm, haven’t seen that one before. Are you positive that it doesn’t appear in p4v? Did it used to exist but was deleted recently? Do other people in your org see it?
Thanks Andrew, I will ask if other can see it as well. Im pretty sure it did used to exist. I has some issues with the import of it. So i may have then removed it and added the new one with a different name.
