Hey guys,
I’m getting a weird DLL declaration mismatch. I’m using FMOD Studio 2.01.11 and I’ve copied over the appropriate files (headers, static lib and DLLs) a bunch of times but still get the same result. The headers are also correct, e.g., the folder matches up and the version is #define FMOD_VERSION 0x00020111
This is our own engine and not Unity or Unreal. This project was updated a couple of years ago so it’s not that old.
Any ideas?
Merry Christmas, Happy Holidays and a Happy New Year to you all!
Matt
We list the requirements for building to windows under FMOD API | Platform Details. Depending on how you are compiling your engine may be causing the issue. Specifically looking at
You will need to use the import library libfmod.a and libfmodstudio.a in order to link the 32 bit dlls.
Hey Connor, I don’t mean to be daft, but can you point me to the code or project settings where those files are imported in the examples? I see that in the docs now (I didn’t see this in the past…). Thank you!
No worries!
The files are located under (BootDrive)\Program Files (x86)\FMOD SoundSystem\FMOD Studio API Windows\api\(core/studio)\lib\x86
Then add your file directories to your visual studio project properties here
