The overview of my implementation goal is that I want layers of music to come and go based on which NPC type is active on the field. For example, when a Knight spawns, the Knight Music Layer turns on (I did this via Label Parameter + Volume Automation). Conversely, when the Knight dies, their music layer disappears.
This works fine and dandy so far, which is great, BUT I would really like the Volume Automation that is triggered by the Label Parameter state to Quantize itself, similar to how my Transition Regions are Quantized. Images below for reference.
Thanks in advance for any insight/assistance yall can provide!
It’s a bit roundabout, but you could have the parameter be the condition for a Command Instrument, which in turn sets a different parameter, which is what actually automates your volume.
You can then set the Command Instrument to have its playback quantised, so it won’t go off until the quantisation interval is reached.
So for example:
A command instrument (which stretches the whole duration of the loop region) has a trigger condition of KnightActive = True, and a trigger quantisation of 1 bar.
When KnightActive goes from False to True, at the start of the next bar, the command instrument goes off, setting the KnightActiveQuantised parameter to True, which turns up the volume of the Knight’s music layer.
A nice side-effect of this is that even though your KnightActive parameter is discrete labelled, the new KnightActiveQuantised parameter can be a continuous parameter from 0-1, so you can give it a seek speed and automate in a fade-in/out instead of just popping the volume up instantly if you like.
oh thats pretty clever! thanks for the idea and response! I realize its a bit of niche situation I’m trying to pull so I really appreciate it
the trouble I’m still having is that it doesnt seem to sync with the music unfortunately. The track starts on the beat properly, but at a different part of the song/harmonic progression than required
your idea has gotten my brain churning though - perhaps I just bounce multiple versions of the track with different variants and use magnet regions that are triggered by the label parameters, that way the playhead pulls to the same part of the song, and magnet regions can be quantized
Oh, perhaps you’re setting the music layer itself to have a conditional start also? It should neither be quantised nor have a playback condition, but instead be set to play silently right away, which should keep it in sync. Then the Command Instrument which is quantised can make the volume come up at the right moment.
Or am I missing something? The magnet region idea isn’t bad, and saves on voice count. It would work especially well if you only ever add/remove layers in order, but if you need to create a version of the track for every possible combination of layers it might get unwieldy.
As of the time of writing (May of 2026) there is no way to quantize an automation value change so that it only happens on the beat.
There are things could could do, though. I’m not sure which will fit what you’re trying to do, so I’ll just lay a few out.
Rather than relying on automation, you could add parameter trigger conditions and quantization to your instruments. Doing so will ensure that your instruments always start on the beat, without the need for volume automation.
You could automate the volume of the Knight track on the timeline instead of on an automated parameter. This will ensure that its volume changes exactly when your transitions occur. This is useful if you only ever need the volume to occur on a transition, but not if you need the volume to change independently of transitions.
As Zanuulme suggests, you could use a quantized command instrument to set the parameter used for volume automation. This will ensure the volume change happens in response to the beat; however, because commands are only processed after they’re issued and can only be processed on update(), there may be a small amount of latency between the instrument being triggered and the parameter value change occurring.
Assuming I didn’t make a mistake in the setup you described (which to be fair I might have), my main issue is even though the start of the command instrument is quantized (and does start on the beat) it doesn’t seek to the specific portion of the KnightActive track that I need, and rather starts at the beginning of the command instrument track (albeit on beat!)
however your solution actually works well for another implementation idea I was working on, so thank you so much!
Thanks for the response Joseph! Your answers on various threads here have been extremely helpful to me throughout my learning process and journey with FMOD.
May I inquire for a deeper explanation of that first point? This seems like it might be the most fitting solution for my case, but I’ don’t think I’m clear on exactly how to set that up.
Of course! Setting trigger conditions and quantization for an instrument is a lot like setting them for a transition marker. Here’s how to do it:
Select one of the instruments that you want to only play under certain conditions.
In the deck, expand the instrument’s “trigger behavior” drawer.
In the “Conditions” section of the drawer, click the “Add Condition” button, then select “Add Parameter Condition > [the specific parameter you’re using to control the event]” from the menu that pops up.
Set the range of the parameter trigger condition to the range of values during which you want the instrument to be audible.
In the “Delay & Quantization” section of the drawer, click on the button corresponding to the quantization interval you want that instrument to use. (From the screenshot, it looks like you’re quantizing to quarter notes.)
Repeat the above steps for each instrument that you only want to play under certain circumstances.
If you follow the above steps correctly, each instrument will only ever begin playing on the beat, and will only do so when the parameter’s value is within the range you specified for that instrument - no automation necessary.
I should mention that you’re using synchronous instruments, and a synchronous instrument plays the part of its waveform that’s overlapped by the playback position - which sounds like the behavior you want. I mention it only because if you were to use asynchronous instruments instead, those instruments would always begin playing from their beginning each time they were triggered, which might be more preferable in other circumstances.
I feel like a proper fool I don’t know why I never thought to just click on the audio files and set trigger conditions I went around and automated the volume with the label parameters probably because I was utilizing them so much on my last project.
This ended up being the solution to what I am trying to achieve. Thanks to both of you for your help here! I’ll mark this as a solution and make an edit in my original post about how quantizing label parameters was not needed for my case.
