Rotating the emitter on a MacBook Pro track pad
Hi There,
In the manual there’s a section on the 3D Preview in the Overview side bar. It says that
Spinning the mouse wheel rotates the emitter.
How do you do this with a MacBook Pro trackpad, when no mouse is attached?
Kind Regards,
Simon.
From FMOD Studio 1.07.00, when using a Mac trackpad, you can use the two-finger swipe gesture in place of a mouse wheel scroll.
OK got it, helps when you push your fingers closer together! Thanks :slight_smile:
