I wrote a little editor script to fetch some data from my FMOD Project in the Editor (it creates a Dictionary containing Events and their Banks). Is there a way to call this automatically when using the “Refresh banks” button? Is there a Callback I can hook into?
There’s no callback you can hook into, but you can modify the relevant source code:
- The bulk of the code for the Bank Refresher is at “./Assets/Plugins/FMOD/src/Editor/BankRefresher.cs”
- The actual process of reading from the updated banks and generating editor assets is handled by
EventManager.RefreshBanks()in “./Assets/Plugins/FMOD/src/Editor/EventManager.cs” - The Bank Fresh window is handled by “./Assets/Plugins/FMOD/src/Editor/BankRefreshWindow.cs”
By the sounds of it, you’ll probably want to insert your code after line 233 of BankRefreshWindow.cs, which is where the code handling the clicking of the “Refresh” button in the bank refresh window is located.
Thank you, that worked perfectly!
