Scatterer without panning?
I’m looking to have a single sound triggered at random intervals, but at a fixed location.
Scatterer seems to do this but pans it all over the place. Any way to disable this?
Multi-sound seems to want to trigger a single sound only once per instance in a track…doesn’t seem like this is normal behavior, but maybe I’m expecting something a multi is not designed to do.
Have you just tried setting min/max distance to 0 ? That will disable volume/panning changes.
I did try that! but it still pans. I think distance in this case only refers to attenuation.
@GregNicolett I can’t reproduce the behaviour you’ve described; Setting the Min & Max distance of the scatterer sound module to 0 definitely disables the scattering behavour. Are you sure you’re setting the Min and Max Distance of the scatterer sound module, and not the 3D Panner effect module?
My bad, I had slid the slider down to “1” instead of “0”. Thanks!
