I don’t know if I’m going crazy, but to me this water drop sound seems different and more “unclean“ in UE5 than what it sounds like in Fmod. In Fmod I have a reverb Return for the SoundFx, And in Ue5 im just calling the Play FmodComponent. The sound in Fmod is “Pummmmmmm“, but in UE5 its like “Prrruummmm“ am I crazy?
Thank you for sharing the information!
From what I can see this is likely expected behaviour. In UE5 the event is being played as a 3D sound and seems to be attached to the instantiated light point, which is some distance away from the player/listener. That means 3D spatialization and distance attenuation are applied, so it won’t sound exactly the same as when you audition it directly in FMOD Studio.
As a quick test, could you please temporarily make the event 2D (remove the Spatializer) and then try it again in UE5?
If it sounds much closer to what you hear in FMOD Studio, that would confirm the difference is coming from the 3D spatialization rather than from the sound itself.
So I removed the spacializer and set the sound to play on Begin Play as a 2D event and it still sounds so different
Thank you for sharing the solution here!
