Quick question: I can “Hide Automation Track” by right clicking on a automation track, which is really convenient. But how can I show them again?
I also noticed when I copy automation via “copy property” and paste it on another track, it will also not show up as an automation track. Is there a way to toggle this?
If you right-click the property to which you’ve added automation, you’ll see the context menu contains a “Show Automation in Editor” command. Click this command, and the automation track will appear in the editor.
As of the time of writing (January of 2025), there is no way to make the “Paste automation and modulation” command automatically show the corresponding automation track in the editor. You will have to use the “Show Automation in Editor” command, as described above.
