Sound downmixed to mono when playing on a ChannelGroup
Hello!
I’ve just hit a weird behavior with a dynamically created/played FMOD::Sound (I need to use Core API because I need to get/setTimelinePosition often and it does not work well with Programmer Sounds)
What I do:
  • on initialization, retrieve and keep a reference to the Track bus that I setup in FMOD Studio to control the volume of the music track and calling MyTrackBus->lockChannelGroup() to ensure it’s always available
  • when selecting a music, create the FMOD::Sound with createSound()
  • when hitting play, first get the ChannelGroup associated with my bus with MyTrackBus->getChannelGroup(&MyTrackChannelGroup)
  • then playing the sound on that channel group using playSound(MySound, MyTrackChannelGroup, false, &MyPlayChannel)
What happens next:
  • the sound is downmixed to mono, by using Live Preview in FMOD studio I specifically see the In view of my Track Bus shows only one side moving
  • weird thing : when moving the Track Bus during Live Preview, the sound gets back to being stereo
  • I tried playing the sound directly on the Master bus (passing nullptr to playSound), the issue does not happen and the sound is properly played as stereo
What do I do wrong and where does it happen? Opening the sound? With the ChannelGroup?
Edit: the issue also happens with a FMOD Event containing a Programmer Instrument. I see that if I leave the Event input format to Automatic, and it contains only a Programmer Instrument, the format is set to mono. And it stays this way after calling SetProgrammerSoundName (from UE4) using a stereo audio file.
If I force the Event format to Stereo (by right-clicking on the input meter), it’s still downmixed to mono and panned to stereo (I see the meter being perfectly in sync on both sides). However, if I add a stereo file as placeholder in the Programmer Instrument, the Event format automatically switches to Stereo, and the playback seems correct (now I see the meters being slightly different on each side).
So what happens when I set a stereo preview that makes the Programmer Sound properly play stereo, and how can I do the same with API calls, given that for this sound I can simply leave the placeholder to have the Programmer Instrument play properly, but I do have another Programmer Sound that I need to play using FMOD system API only.
Edit2 : I fixed my problem by setting up a programmer sound with a stereo preview to be routed to my Track Bus, forcing it to stereo format. Now if I create and play a Sound on that Bus as described in my first post, there is no downmixing.
So no urge here, my problem is fixed, but I would be curious to get some insight on what happened here and some best practices using Programmer Sounds.
Thank you for sharing the solution to your problem, apologies I didn’t get back to you. I will continue to investigate this and if I find anything I will let you know.
Again, thank you!
Hi there! Just wanted to report that we also ran into this problem and were able to fix it thanks to Bnnoy’s experiments and efforts.
Would be fantastic to have an official fix for this :wink:
