How come the sound of the yellow clip does not stop men the cursor is not on top of it. As seen in the clip this causes the sound from the yellow clip to play double.
What am I doing wrong? When looking at instruction videos on youtube this phenomenon does not seem to happen.
Instruments on a parameter sheet are asynchronous, meaning the start to play once triggered. By default they will play out to the end unless you specify it not to. Select the instrument and enable the “Cut” button in the deck. This should untrigger the instrument once the playback position leaves the instruments location.
