I experience undesired behaviour with default device choice FMOD makes to output sounds.
When the default Windows audio output device is set to something other than Rift, e.g. headphones, there will be no audio in the experience. How can I force FMOD to play through the rift? The ue4 default sound engine always outputs audio through the rift when connected.
We use both of the sound engines in our project, and it happens only the non-FMOD sounds are played correctly played. It is even more disturbing than no sound at all!
Everything it setup correctly, and there is no warnings in the logs.
Here is a screenshot of my Windows 8.1 sound panel to let you check if you can reproduce the issue. https://framapic.org/6zyIJrqrtuOG/qJCA774fQjIl.png
Realteak Soundcard is set as default sound device and Rift as ‘Ready’. Everything else is disabled.
I updated FMOD and did not realize a new option was available in the plugin configuration. I set Initial Output Driver Name to Rift Audio and now everything works a charm.
