Sound propagation for Riverside-like SoundFX
since FMOD 3D sound are by default propagated in a spherical fashion, I wish to know wich is the best way to create a “wall-of-sound”, I mean an object that can emit a single soundFX in a sort of cubic propagation.
This could be very useful for ambience sounds that has to be placed on seashore, riverside etc
The provided built-in parameters (distance, angle, etc) and the Sound-Size or Min-Extent params seems to be not very useful to build something that cover a big range preserving at the same time the spatial localization of that sounds
At the moment I’m placing multiple emitters all the way long, tweaking their Min/Max distance, but is very difficult to avoid sound-power discontinuity
Do you have any method/suggestions?
Thank you for your help
Gianni Ricciardi
Yes, you are correct that the built-in 3D sound support is designed for spherical emitters only.
It’s probably easiest for you to perform your custom wall-of-sound attenuation in code and then feed that to the event via a parameter. You can setup that parameter to automate the event’s master volume appropriately.
For example, you could create a parameter called “WallDistance”, with a range from say 0 to 200 meters. Have this parameter automate the event’s master volume with a curve just like the regular inverse-square fall-off. In game, you calculate the distance from the listener to the nearest point on the wall and call Studio::EventInstance::setParameterValue(“WallDistance”, distance_to_listener).
As for direction, you can still rely on FMOD’s 3D Panner to take care of this. Call Studio::EventInstance::set3DAttributes and pass it the nearest point on the wall. Just make sure you turned off the built-in distance attenuation, since you will be doing that yourself via the “WallDistance” parameter.
