I try to make an event that is basically 2D, and for 2 tracks are 3D. When it is playing, the bulletin distance parameter controls volume, while the 3D tracks can be heard with location information.
So I made a 2D event first, then I add the bulletin parameter and the Spatializer. When I try to set the Pan Override, I saw two different type in the two tracks.
I am not sure what’s different between ‘Axis/Width’ ‘Direction/Extent’ and why it occurs differently in two tracks?
Thank you!
