Stacked Logic Marker Margin Issue
Description
When you zoom all tracks in or out vertically using ⌘[/](I assume it’s ⌃[/] on PC), the vertical margin on Logic Markers increases.
Video
FMOD Studio Logic Marker Margin Issue
Steps to Reproduce
  • Make a new FMOD Studio Project.
  • Make a new Event.
  • Add a Timeline to that Event.
  • Add a Track or two if you wish.
  • Add some stacked Logic Markers.
    • The effect is visible with only 2 Markers stacked, but you really start to see the exaggerated effect with around 5 or 6 stacked Markers.
  • Using the key command, zoom all Tracks in or out vertically.
  • Aside from the Tracks changing in size, the vertical margin between Logic Markers increases.
Expected Result
  • Only the vertical size of the Tracks change.
Workaround
  • Deselect the Event (or select another one) and come back to the one you were editing.
  • The margins of the Logic Markers are reset.
Notes
  • If you’ve adjusted the Track size manually, the key command to zoom in/out vertically no longer changes the Track size, but it still adds the same margin to the Logic Markers.
Severity
Minor annoyance (non-blocking)
Version
FMOD Studio 2.03.14
Thanks for the bug report! It looks like changing the standard track height forces the logic tracks to be redrawn using a specific scale that differs from the correct scale.
I’ve added the issue to our bug tracker. We’ll fix it in an upcoming release of FMOD Studio.
