Sub Group Mixing With Resonance Audio Pre Production Question
Does using Resonance audio spatializer practically means losing the ability to mix with sub mix groups in FMOD, or am I am missing something?
If all spatialized audio sources need to be routed to a single group, and you can’t have more than one Resonance Audio Listener plug-in, effectively means no sub busses separation of explosions, VO, weapons etc. Correct?
Thank you in advance.
You’re not missing anything; that’s exactly what it means.
This is a known limitation of the Resonance Audio effects, and has been raised as an issue on Resonance Audio’s GitHub page.
