If you reduce the range of a parameter, Studio offers you an option to either Trim or Scale the automation built into the parameter. However, if you increase the range, no such options are offered.
Often I want the envelopes to cover the entire range of the parameter, but then find out I need to increase its range, but also stretch the envlopes to cover the whole new range. Without the scale option it can turn out to be a bit laborious.
I’d appreciate if it was possible to upscale parameter automation too.
