Hi all,
Here’s a simplified explanation of what I’m trying to do:
I have an EQ with the X-High control tied to the parameter Intensity
In section A of the timeline I’d like the Intensity parameter to control X-High between the ranges of 500Hz to 2Khz
In section B of the timeline I’d like the Intensity parameter to now control X-High between the ranges of 1Khz to 2Khz
In section C etc etc
I have a bunch of sections
The only way I can think of doing this is having a separate EQ plug for each section of the timeline, but this seems really inefficient and trying to make a smooth shift between different EQs seems nigh-on impossible.
What I’ve written in the title would be the ideal solution, but as far as I’m aware that’s not possible in FMOD?
I’d be very grateful if someone has a better solution!
