So I’m trying to get the final, rendered audio out of FMOD 1.06.03 in Unity 5.0.2f1. I’m using what I believe is the proper way to get it - creating a DSP with a read callback. This seems to work fine in Unity’s playmode. However, running on an iOS device and I get this error:
ExecutionEngineException: Attempting to JIT compile method '(wrapper managed-to-native) FMOD.System:FMOD5_System_CreateDSP (intptr,FMOD.DSP_DESCRIPTION&,intptr&)' while running with --aot-only.
Why would this happen for createDSP? I’m also using createDSPByType, which works fine on the device. Is there something magical I need to do with the callbacks? Even when I leave the DSP_DESCRIPTION blank, I get this issue.
