Trigger Cue in a referenced Event
Ey.
Thank you for your time in advance!
I’ve been looking for imformation about this but I haven’t found anything (nor in the manual, nor in the forum).
I would love to know if there is any way of triggering a cue in a referenced event (the same way you can control a parameter from the “father” event to the referenced one).
Thank you!
Celer
There is currently no way to key off a sustain point in a nested event instance.
Until we are able to implement this feature, we recommend using loop regions with parameter conditions as an alternative way of keeping the timeline cursor from advancing. If this solution isn’t sufficient for your project, please contact support with a description of your issue, and we’ll help you find a solution that works.
Is it still impossible to keyoff a sustain point in a nested event?
(I saw i could create a cue inside a nested event, contained in the parameter of my event)
thx
It is still impossible. Again, we recommend using loop regions with parameter conditions as a replacement.
