Sevada
December 14, 2024, 1:41pm
1
So we had this issue after upgrading our project to UE 5.5, where our project crashes on the second launch, after FMOD assets have been build inside FMOD folder. And we get this errors:
[2024.12.14-13.21.31:052][ 1]LogUObjectLinker: Error: Detaching from existing linker /Game/FMOD/Events/Projectiles/Grenade/GrenadeExplosion while object MetaData None.PackageMetaData needs loading (Standalone | NeedLoad | NeedPostLoad | NeedPostLoadSubobjects | WasLoaded). Setting linker to nullptr. See log for more information.
[[2024.12.14-13.21.31:628][ 1]]LogStreaming: Error: AsyncRoot still associated with Linker
Array index out of bounds: 0 into an array of size 0.
It dissapears when we delete the folders inside FMOD folder, and launch the project again. Then everything is back to normal, until after we try to re-launch our project again. Can this be related to FMOD version (5.4) incompatibility with UE 5.5?
We have an official version for UE5.5 on our downloads page now, can you try that an see if it fixes your issue?
We just upgraded from UE5.4 to UE5.5.3 in our project and are using FMOD version 2.03.06 now, but this issue is still there unfortunately.
The symptoms are the same as @Sevada described.
Could you please have a look into this?
We can work around the issue for now, but we would really appreciate a bug fix.
Please let me know if I can provide you with any additional info that might help you.
Here’s my log output (renamed project paths and event names due to NDA)
Display LogStreaming FlushAsyncLoading(669): 1 QueuedPackages, 523 AsyncPackages
Error LogUObjectLinker Detaching from existing linker /Game/FMOD/Events/OBJECTS/SFX_EVENT_IN_SUBFOLDER while object FMODEvent None.SFX_EVENT_NAME needs loading (Public | Standalone | NeedLoad | NeedPostLoad | NeedPostLoadSubobjects | WasLoaded). Setting linker to nullptr. See log for more information.
Log LogStats FPlatformStackWalk::StackWalkAndDump - 0.278 s
Display LogOutputDevice === FDebug::DumpStackTrace(): ===
Display LogOutputDevice [Callstack] 0x00007fff008c7845 UnrealEditor-CoreUObject.dll!UObject::SetLinker() [PROJECT_FOLDER\Engine\Source\Runtime\CoreUObject\Private\UObject\UObjectLinker.cpp:129]
Display LogOutputDevice [Callstack] 0x00007fff005f5e20 UnrealEditor-CoreUObject.dll!FLinkerLoad::DetachExports() [PROJECT_FOLDER\Engine\Source\Runtime\CoreUObject\Private\UObject\LinkerLoad.cpp:6023]
Display LogOutputDevice [Callstack] 0x00007fff005f4801 UnrealEditor-CoreUObject.dll!FLinkerLoad::Detach() [PROJECT_FOLDER\Engine\Source\Runtime\CoreUObject\Private\UObject\LinkerLoad.cpp:6044]
Display LogOutputDevice [Callstack] 0x00007fff006ffb92 UnrealEditor-CoreUObject.dll!UPackage::FinishDestroy() [PROJECT_FOLDER\Engine\Source\Runtime\CoreUObject\Private\UObject\Package.cpp:370]
Display LogOutputDevice [Callstack] 0x00007fff0066ca0b UnrealEditor-CoreUObject.dll!UObject::ConditionalFinishDestroy() [PROJECT_FOLDER\Engine\Source\Runtime\CoreUObject\Private\UObject\Obj.cpp:1247]
Display LogOutputDevice [Callstack] 0x00007fff00890670 UnrealEditor-CoreUObject.dll!StaticAllocateObject() [PROJECT_FOLDER\Engine\Source\Runtime\CoreUObject\Private\UObject\UObjectGlobals.cpp:3586]
Display LogOutputDevice [Callstack] 0x00007fff00891f10 UnrealEditor-CoreUObject.dll!StaticConstructObject_Internal() [PROJECT_FOLDER\Engine\Source\Runtime\CoreUObject\Private\UObject\UObjectGlobals.cpp:4527]
Display LogOutputDevice [Callstack] 0x00007fff008479c0 UnrealEditor-CoreUObject.dll!CreatePackage() [PROJECT_FOLDER\Engine\Source\Runtime\CoreUObject\Private\UObject\UObjectGlobals.cpp:1100]
Display LogOutputDevice [Callstack] 0x000001e301598dec UnrealEditor-FMODStudioEditor.dll!FFMODAssetBuilder::CreateAsset() [PROJECT_FOLDER\Ghost\Plugins\FMODStudio\Source\FMODStudioEditor\Private\FMODAssetBuilder.cpp:536]
Display LogOutputDevice [Callstack] 0x000001e301595dd6 UnrealEditor-FMODStudioEditor.dll!FFMODAssetBuilder::BuildAssets() [PROJECT_FOLDER\Ghost\Plugins\FMODStudio\Source\FMODStudioEditor\Private\FMODAssetBuilder.cpp:147]
Display LogOutputDevice [Callstack] 0x000001e30159a482 UnrealEditor-FMODStudioEditor.dll!FFMODAssetBuilder::ProcessBanks() [PROJECT_FOLDER\Ghost\Plugins\FMODStudio\Source\FMODStudioEditor\Private\FMODAssetBuilder.cpp:51]
Display LogOutputDevice [Callstack] 0x000001e3015d2d52 UnrealEditor-FMODStudioEditor.dll!FFMODStudioEditorModule::ReloadBanks() [PROJECT_FOLDER\Ghost\Plugins\FMODStudio\Source\FMODStudioEditor\Private\FMODStudioEditorModule.cpp:1242]
Display LogOutputDevice [Callstack] 0x000001e3015d0bd8 UnrealEditor-FMODStudioEditor.dll!FFMODStudioEditorModule::ProcessBanks() [PROJECT_FOLDER\Ghost\Plugins\FMODStudio\Source\FMODStudioEditor\Private\FMODStudioEditorModule.cpp:388]
Display LogOutputDevice [Callstack] 0x000001e3015cc5cd UnrealEditor-FMODStudioEditor.dll!TBaseFunctorDelegateInstance<void __cdecl(void),FDefaultTSDelegateUserPolicy,`FFMODStudioEditorModule::OnPostEngineInit'::`36'::<lambda_1> >::ExecuteIfSafe() [PROJECT_FOLDER\Engine\Source\Runtime\Core\Public\Delegates\DelegateInstancesImpl.h:872]
Display LogOutputDevice [Callstack] 0x00007fff027c5343 UnrealEditor-AssetRegistry.dll!TMulticastDelegate<void __cdecl(void),FDefaultTSDelegateUserPolicy>::Broadcast() [PROJECT_FOLDER\Engine\Source\Runtime\Core\Public\Delegates\DelegateSignatureImpl.inl:1079]
Display LogOutputDevice [Callstack] 0x00007fff027c6c85 UnrealEditor-AssetRegistry.dll!UAssetRegistryImpl::Broadcast() [PROJECT_FOLDER\Engine\Source\Runtime\AssetRegistry\Private\AssetRegistry.cpp:9285]
Display LogOutputDevice [Callstack] 0x00007fff028202dd UnrealEditor-AssetRegistry.dll!UAssetRegistryImpl::Tick() [PROJECT_FOLDER\Engine\Source\Runtime\AssetRegistry\Private\AssetRegistry.cpp:4751]
Display LogOutputDevice [Callstack] 0x00007ffef10398c2 UnrealEditor-UnrealEd.dll!UEditorEngine::Tick() [PROJECT_FOLDER\Engine\Source\Editor\UnrealEd\Private\EditorEngine.cpp:1900]
Display LogOutputDevice [Callstack] 0x00007ffef1ccbbc6 UnrealEditor-UnrealEd.dll!UUnrealEdEngine::Tick() [PROJECT_FOLDER\Engine\Source\Editor\UnrealEd\Private\UnrealEdEngine.cpp:550]
Display LogOutputDevice [Callstack] 0x00007ff6471f6ce7 UnrealEditor.exe!FEngineLoop::Tick() [PROJECT_FOLDER\Engine\Source\Runtime\Launch\Private\LaunchEngineLoop.cpp:5877]
Display LogOutputDevice [Callstack] 0x00007ff6472157ac UnrealEditor.exe!GuardedMain() [PROJECT_FOLDER\Engine\Source\Runtime\Launch\Private\Launch.cpp:188]
Display LogOutputDevice [Callstack] 0x00007ff647219175 UnrealEditor.exe!LaunchWindowsStartup() [PROJECT_FOLDER\Engine\Source\Runtime\Launch\Private\Windows\LaunchWindows.cpp:266]
Display LogOutputDevice [Callstack] 0x00007ff64722bd04 UnrealEditor.exe!WinMain() [PROJECT_FOLDER\Engine\Source\Runtime\Launch\Private\Windows\LaunchWindows.cpp:317]
Display LogOutputDevice [Callstack] 0x00007ff64722f0ba UnrealEditor.exe!__scrt_common_main_seh() [D:\a\_work\1\s\src\vctools\crt\vcstartup\src\startup\exe_common.inl:288]
Display LogOutputDevice [Callstack] 0x00007fff90037374 KERNEL32.DLL!UnknownFunction []
Display LogOutputDevice [Callstack] 0x00007fff90a9cc91 ntdll.dll!UnknownFunction []
Error LogUObjectLinker Detaching from existing linker /Game/FMOD/Events/OBJECTS/SFX_EVENT_IN_SUBFOLDER while object MetaData None.PackageMetaData needs loading (Standalone | NeedLoad | NeedPostLoad | NeedPostLoadSubobjects | WasLoaded). Setting linker to nullptr. See log for more information.
Log LogStats FPlatformStackWalk::StackWalkAndDump - 0.006 s
Error LogStreaming AsyncRoot still associated with Linker
Experiencing the same thing. Using UE 5.5 and FMOD 2.02.26
Sidera
February 19, 2025, 2:38am
5
@Ravenlord Having the same issue you are with my project. How are you working around this? The editor is crashing on every start up for me.
@Sidera after lots of unsuccessful tries I tried commenting out the initial call to FFMODStudioEditorModule::ProcessBanks (actually the whole lambda registration to AssetRegistry.Get().OnFilesLoaded()) in FFMODStudioEditorModule::OnPostEngineInit.
This will work around the crash, but you won’t have any asset information loaded (e.g. in Event uassets) and preview sounds in the editor won’t work, but at least nothing crashes (sound in PIE still works though).
We then added a button to SFMODEventEditorPanel to be able to manually trigger it in a rather user-friendly way. You can also just go to Project Settings and uncheck/check Project Settings → Plugins → FMODStudio → Load all banks to do it.
It’s a messy workaround, but it does the trick for us until we get a proper fix.
If anyone is able to reproduce this issue in a small project that they are able to share, I would greatly appreciate it as I have been unable to reproduce this myself so far.
@Ravenlord @Sidera @mjohnson3484
Could I get some more information about your projects:
Are you using the retail engine (from the Epic Launcher) or the source engine?
Which specific version/changelist?
Has your project upgraded/migrated from a different UE version?
Are you using source control?
Which source control?
Are you using the in-editor source control integration.
Are the generated assets added to source control?
Which version of the FMOD integration are you using?
Have you upgraded from another major version at any point?
Which version of FMOD Studio are you using?
Can you share any logs/callstacks/crashdumps?
I have been able to find quite a few reports of this in the Unreal forums, but all coming from different origins and all with different solutions.
Getting more information and trying to reproduce this is the first steps.
Sorry, I don’t have a test project I can share at this time, but I can tell you some settings/circumstances, which seem to be connected to this crash.
Have any map available with a couple of objects in it.
Set the editor to load the last opened map on startup.
Make sure to have exported banks and generated assets on disk.
It might take a couple of editor startups for the crash to happen, but then it crashes consistently.
Now to your questions:
We are using the source engine in version 5.5.3 (don’t know the CL).
We have recently upgraded from 5.4.
Our project is using perforce/Helix. In-Editor source control is enabled and the generated assets are added to the depot (our sound engineers submit them every time they export banks).
FMOD version 2.03.06 (for 5.5 of course), but the crash also happened in 2.02.22 (for UE5.4) after updating the engine version to 5.5.
Our sound engineers use FMOD Studio 2.03.06 to match our in-game version.
I shared the callstack in my initial post. It’s always the same.
The Unreal forum posts you linked seem to be completely unrelated I’m afraid. If you look at the callstack in my previous post, it’s very clear the crash is happening in the FMODStudioEditorModule::ProcessBanks (and further down the line in FFMODAssetBuilder).
My current working theory is the following: The call to ProcessBanks is registered in a lambda to AssetRegistry.Get().OnFilesLoaded(). The internals of how/when this event is fired changed from UE5.4 to UE5.5 however, so whatever ProcessBanks tries to do internally might not be safe or guaranteed at this point anymore.
When manually calling ProcessBanks at a later point in time in the editor will not produce the crash, which supports this theory.
Thanks for looking into this. I hope this information helps.
I don’t have a smaller project to share unfortunately. Behavior and logs still consistent with my original post here.
Retail 5.5.1
Yes, upgraded from 5.2
Yes
Perforce / P4V
Using in editor source control integration
Generated assets are added to source control
Using (2.02.26) Patch 1 | UE5.5 integration
Using FMOD Studio version 2.02.26
UE Crash report in linked post
Are you using the Gameplay Ability or Effect systems at all?
We have another report of this same issue and it seems to be linked to the loading of assets related to those systems: Some FMOD Event assets changed on every Editor launch - #3 by dquartz .
Yes, we heavily utilize those systems.
I tried setting the GameplayCueManager to load stuff synchronously in the editor as proposed in the other forum thread for the fun of it, but that also does not fix the crash for me.
Yes, we are using those systems as well. We’ll try this out
We have a workaround for now, in FMODAssetBuilder.cpp add a call to FlushAsynLoading() in the ProcessBanks() function before everything else:
void FFMODAssetBuilder::ProcessBanks()
FlushAsyncLoading();
We are continuing to investigate the best solution for our integration.
Looks like a fix was committed today in regards to this issue. I have personally not tested it out.
We will have to test it out too, but we will still see if there is a fix we can make for the current versions.
I installed latest plugin and this doesn’t seem fixed. Any update on this issue?
It’s a direct crash on load, can’t start editor. Seems like something that would require a fix relatively quickly.
Can you share the callstack from your crash?
Which exact versions of FMOD and Unreal are you using?
I’m using 5.6 (from launcher) with fmod 2.03.08
But it was exactly the same issue with 5.5 and 2.03.06
We are also using perforce, just like the original post.
Yes we are using GAS, and it was a GameplayCue in particular that was causing the issue in my case. I don’t have the callstack from the crash anymore. It might be a bit different that the one from the original post tho. But same symptoms, and more importantly same fix (FlushAsyncLoading).
Here is the callstack
[Inlined] TArray::operator[](int) Array.h:1146
FAsyncPackage2::ResolveLinkerLoadImports(FAsyncLoadingThreadState2 &) AsyncLoading2.cpp:6962
FAsyncPackage2::Event_ResolveLinkerLoadImports(FAsyncLoadingThreadState2 &, FAsyncPackage2 *, int) AsyncLoading2.cpp:7246
FEventLoadNode2::Execute(FAsyncLoadingThreadState2 &) AsyncLoading2.cpp:5713
FAsyncLoadEventQueue2::ExecuteSyncLoadEvents(FAsyncLoadingThreadState2 &) AsyncLoading2.cpp:5919
FAsyncLoadingThread2::ProcessAsyncLoadingFromGameThread(FAsyncLoadingThreadState2 &, bool &) AsyncLoading2.cpp:9215
[Inlined] FAsyncLoadingThread2::TickAsyncThreadFromGameThread(FAsyncLoadingThreadState2 &, bool &) AsyncLoading2.cpp:9946
FAsyncLoadingThread2::TickAsyncLoadingFromGameThread(FAsyncLoadingThreadState2 &, bool, bool, double, TArrayView<…>, bool &) AsyncLoading2.cpp:9565
FAsyncLoadingThread2::FlushLoading(TArrayView<…>) AsyncLoading2.cpp:11241
FlushAsyncLoading(TArrayView<…>) AsyncPackageLoader.cpp:362
FlushAsyncLoading(int) AsyncPackageLoader.cpp:331
LoadPackageInternal(UPackage *, const FPackagePath &, unsigned int, FLinkerLoad *, FArchive *, const FLinkerInstancingContext *, const FPackagePath *) UObjectGlobals.cpp:1771
LoadPackage(UPackage *, const FPackagePath &, unsigned int, FArchive *, const FLinkerInstancingContext *, const FPackagePath *) UObjectGlobals.cpp:2135
LoadPackage(UPackage *, const wchar_t *, unsigned int, FArchive *, const FLinkerInstancingContext *) UObjectGlobals.cpp:2111
UPackage::FullyLoad() Package.cpp:309
FFMODAssetBuilder::CreateAsset(const FFMODAssetBuilder::AssetCreateInfo &, TArray<…> &) FMODAssetBuilder.cpp:542
FFMODAssetBuilder::BuildAssets(const UFMODSettings &, const FString &, const FString &, TArray<…> &, TArray<…> &) FMODAssetBuilder.cpp:148
FFMODAssetBuilder::ProcessBanks() FMODAssetBuilder.cpp:52
FFMODStudioEditorModule::ReloadBanks() FMODStudioEditorModule.cpp:1244
FFMODStudioEditorModule::ProcessBanks() FMODStudioEditorModule.cpp:386
[Inlined] FFMODStudioEditorModule::OnPostEngineInit::__l36::<lambda_1>::operator()() FMODStudioEditorModule.cpp:370
[Inlined] Invoke(<lambda_1> &) Invoke.h:47
[Inlined] UE::Core::Private::Tuple::TTupleBase::ApplyAfter(<lambda_1> &) Tuple.h:320
TBaseFunctorDelegateInstance<void __cdecl(void),FDefaultTSDelegateUserPolicy,`FFMODStudioEditorModule::OnPostEngineInit'::`36'::<lambda_1> >::ExecuteIfSafe() DelegateInstancesImpl.h:892
[Inlined] TMulticastDelegateBase::Broadcast() MulticastDelegateBase.h:258
TMulticastDelegate::Broadcast() DelegateSignatureImpl.inl:1080
UAssetRegistryImpl::Broadcast(UE::AssetRegistry::Impl::FEventContext &, bool) AssetRegistry.cpp:9855
UAssetRegistryImpl::Tick(float) AssetRegistry.cpp:4865
[Inlined] FAssetRegistryModule::TickAssetRegistry(float) AssetRegistryModule.h:58
UEditorEngine::Tick(float, bool) EditorEngine.cpp:1909
UUnrealEdEngine::Tick(float, bool) UnrealEdEngine.cpp:530
FEngineLoop::Tick() LaunchEngineLoop.cpp:5619
[Inlined] EngineTick() Launch.cpp:60
GuardedMain(const wchar_t *) Launch.cpp:189
LaunchWindowsStartup(HINSTANCE__ *, HINSTANCE__ *, char *, int, const wchar_t *) LaunchWindows.cpp:271
WinMain(HINSTANCE__ *, HINSTANCE__ *, char *, int) LaunchWindows.cpp:339
[Inlined] invoke_main() 0x00007ff67cce80fa
__scrt_common_main_seh() 0x00007ff67cce80d9
<unknown> 0x00007ffb58dbe8d7
<unknown> 0x00007ffb5a37c34c
