Hey guys, I’m trying to install FMOD on UE4, (I’m using the source code no the binary version!)
I used to run FMOD on the binary version and everything was fine, but now is not working. I see this message ‘‘Plugin ‘FMODStudio’ failed to load because module ‘FMODStudio’ could not be found. Please ensure the plugin is properly installed, otherwise consider disabling the plugin for this project’’. Can someone help? Thanks
