When I click Build, it runs few seconds and then ends it. The messages I get are about FMODStudioFootstepsEditor.cs
Assets\Editor Default Resources\FMODStudioFootstepsEditor.cs(23,26): error CS0115: ‘FMODStudioFootstepsEditorTwo.OnInspectorGUI()’: no suitable method found to override
Assets\Editor Default Resources\FMODStudioFootstepsEditor.cs(21,45): error CS0246: The type or namespace name ‘Editor’ could not be found (are you missing a using directive or an assembly reference?)
Assets\Editor Default Resources\FMODStudioFootstepsEditor.cs(20,2): error CS0246: The type or namespace name ‘CustomEditorAttribute’ could not be found (are you missing a using directive or an assembly reference?)
Assets\Editor Default Resources\FMODStudioFootstepsEditor.cs(20,2): error CS0246: The type or namespace name ‘CustomEditor’ could not be found (are you missing a using directive or an assembly reference?)
Assets\Editor Default Resources\FMODStudioFootstepsEditor.cs(7,42): error CS0246: The type or namespace name ‘Editor’ could not be found (are you missing a using directive or an assembly reference?)
Any idea why this happens? Thanks in advance! ![]()
