The normal unity android build (without split by binary) will work without problems. After spliting the apk and obb (as needed for >100mb apps) the sound will not work. Do I have to change anything?
Thx.
Thx.
You’ll need to make some changes. The simplest would be to use Unity’s WWW class to read the .bank files from the assets folder within the OBB and write them into the Application.persistentDataPath folder. Then in FMOD_Listener.cs change
bankPath = "file:///android_asset";
to
bankPath = Application.persistenDataPath;
Thank you for helping out. We had some other priority bugs to fix :), so sorry for the late response.
Here is our code, free to use (do not forget to change banks ="", see answer above):
WWW wwwAllBanksTextFile = new WWW( System.IO.Path.Combine( Application.streamingAssetsPath, "FMOD_bank_list.txt" ) );
yield return wwwAllBanksTextFile;
if( wwwAllBanksTextFile.error == null )
string[] banks = wwwAllBanksTextFile.text.Split( '\n' );
foreach( string bank in banks )
if( bank.Length <= 0 )
continue;
// try to open persistent file:
WWW wwwBankPersistentFile = new WWW( System.IO.Path.Combine( Application.persistentDataPath, bank ) );
yield return wwwBankPersistentFile;
// if not found: not in persistent file space
if( wwwBankPersistentFile.error != null )
// Try to copy it from streaming assets path
WWW wwwBankTmp = new WWW( System.IO.Path.Combine( Application.streamingAssetsPath, bank ) );
yield return wwwBankTmp;
if( wwwBankTmp.error == null )
File.WriteAllBytes( System.IO.Path.Combine( Application.persistentDataPath, bank ), wwwBankTmp.bytes );
else
ErrorText.text += "ERROR 1002: " + bank + " file in streaming storage not found!\n";
else
ErrorText.text += "ERROR 1003: Bank list not found!\n";
1.07.04 will have support for split binary out of the box in both the 2.0 and Legacy integrations.
