Unity can't find the 'Motors2' audio plugin; troubleshooting is needed
"I created a PRM sound effect using the Audio Motors2 plugin, but it’s not working in Unity due to the following error: ‘[FMOD] PostLoad::initPluginEffects: DSP plugin returned an error, bank will not load properly.’
It works in FMOD Studio, and when I remove the event that includes the plugin, the FMOD bank works correctly in Unity. However, I want to use the Audio Motors2 plugin in Unity. Could you please provide some assistance with this issue? Thanks!
my unity version is 22.03.11f / fmod studio is 2.02.18
LeSound, the creators of the AudioMotors plugin, has closed permanently. AudioMotors is no longer available to buy. You will need to find a different solution for your car sounds.
https://lesound.io/product/audiomotors-pro/
I checked. Thank you.
(This thread is actually referenced quite well in search engines so I figured I could as well reply to it - and sorry for the necroposting.)
LeSound plugins have been taken over, although there is no “public display” yet you may get in touch at contact@lesound.io
