Please help, there is no sound in the unity editor. According to the logs in Linux, it can be seen that the sound is sent to the HDMI port and not to the main port of the audio card as other applications do.
ScreenShoot
Tell me can I fix it somehow. Thank you.
Just to clarify, are you using FMOD Studio and the FMOD for Unity plugin, or just Unity’s default audio system? If it’s the latter, unfortunately I can’t be of any help, and you’ll want to post this on the Unity forums instead - the reason you’re seeing “FMOD” here is that Unity’s audio system is based on an old version of FMOD.
Its possible you have hit this Unity bug.
