Hello, i am trying to integrate FMOD with UE 5.1. the step on the user guide calls for validating FMOD through the unreal help menu. but that option does not exist for me.
under project settings > plugins > FMOD
i am getting a hint to run the validate FMOD command. is there a different way i can run it now? Thank you.
You can find the Validate FMOD option under the Help Editor toolbar option:
What version of the Unreal Integration are you using? The Validate FMOD option should be available in 5.1. Thanks
I am using 5.1 and I dont see a validate option. Although everything seems to be working fine as far as i can tell so i guess validating isnt that big a deal anyway
Apologies, I meant what version of the FMOD Unreal integration are you using e.g. 2.02.XX?
2.02.19
The validate option actually showed up for me today. i am not sure what triggered it but everything is working great now, thank you!
Good to hear it is working!
