Voice chat problem
I working on a project where we have a voice chat, and all the voices are handled by FMOD.
I have a question about the creation and playing of the sound from the CORE level.
How do We can load all the sounds created on a BUS?
This will solve our problem of return on the speaking…
    FMODLib.MODE soundMode = FMODLib.MODE.OPENUSER |
    FMODLib.MODE.LOOP_NORMAL;
    res = FMODUnity.RuntimeManager.CoreSystem.createSound("Photon AudioOut", soundMode, ref exinfo, out sound);
    if (res != FMODLib.RESULT.OK)
        Error = "failed to createSound: " + res;
        logger.LogError(logPrefix + Error);
        return;
    voiceReciveBus = FMODUnity.RuntimeManager.GetBus("bus:/Voices/VoiceReceive");
    voiceReciveBus.getChannelGroup(out voiceReciveChannel);
    res = coreSystem.playSound(sound, voiceReciveChannel, false, out channel);
    channel.getChannelGroup(out FMODLib.ChannelGroup cg);
        Error = "failed to playSound: " + res;
        return;
This code works fine but on the mixer we get nothing…
I hope to find a solution.
Kind regard,
Nicholas
we’re working and got stuck on a similar case any hint about it would be appreciated.
Same problem here!
Ideally you don’t want to be digging into the Core API of Studio objects, but you should be able to use an event containing a programmer instrument. This will handle the issue of attaching your Core level sound to the Studio System.
FMOD - Scripting Examples | Programmer Sounds
Alright so I was trying to do the same thing ( I am using Photon Voice + FMOD)
This is the correct way to do this
            FMODLib.GUID busGUID = FMODLib.GUID.Parse("GUID HERE (GET IT FROM FMOD STUDIO MIXER");
            FMODLib.Studio.Bus targetBus;
            FMODUnity.RuntimeManager.StudioSystem.getBusByID(busGUID, out targetBus);
            var lockResult = targetBus.lockChannelGroup();
            FMODUnity.RuntimeManager.StudioSystem.flushCommands();
            targetBus.getChannelGroup(out var busChannelGroup);
            FMODLib.RESULT res = coreSystem.playSound(sound, busChannelGroup, false, out channel);
I am not sure why it works this way and not the one you wrote but it does
Best,
Alex
