Warning generated by .assets and .streams bank names
Hi FMOD,
I recently upgraded our UE4 project to 2.01.05 (4.25+) and I see you have added a warning:
LogFMOD: Warning: ‘Score Tick’ cannot be used as a UE4 asset name. Name may not contain the following characters: . Using ‘Score_Tick’ instead.
LogFMOD: Warning: ‘Music.streams’ cannot be used as a UE4 asset name. Name may not contain the following characters: … Using ‘Music_streams’ instead.
I approve of the warning and I realise that we should rename all our events to fix this. However, I’m not sure how to fix the streams/assets bank names. FMOD automatically uses the extensions “.streams.bank” or “.assets.bank” during the build and I can’t find anyway to change this. What is your recommended solution to get rid of this warning?
Thanks
Alex
It helped me to switch to the union banks
but it is clear that the solution is temporary
As far as I can tell, the Unreal projects will continue to work as intended but with slightly changed bank names. I’ll raise this as a concern for our integration devs to look into if this could cause problems down the track, but otherwise this just appears to be a harmless warning.
