xushp
July 26, 2015, 4:21pm
1
recently!I am learning about unity integration of fmod.
When I browse document about fmod? I was confused with several words:bus,channel,vda,dsp.
It’s so kind of you to answer this question?
joseph
July 27, 2015, 4:02am
2
To clarify, are you asking for definitions of those four words?
Micha
July 31, 2015, 11:44am
4
Bus, Channel and VCA are components of the mixer in Fmod Studio. This mixer imitates hardware mixing desks like they have been used for decades in recording studios.
For explainations, you could read this:
How to Use an Audio Mixer (soundboard): In this instructable I am going to go through all the control features found on most mixers (mixing consoles, mixing desks, audio consoles, soundboards - they all refer to the same thing). I will start with the...
DSP stands for Digital Signal Processing:
Digital signal processing (DSP) is the use of digital processing, such as by computers or more specialized digital signal processors, to perform a wide variety of signal processing operations. The digital signals processed in this manner are a sequence of numbers that represent samples of a continuous variable in a domain such as time, space, or frequency. In digital electronics, a digital signal is represented as a pulse train, which is typically generated by the switching of a transistor Digit...
Hope this helps,
Micha
xushp
August 1, 2015, 3:42pm
5
It’s helpful to me. Thanks a lot!
