Hello, I’ve come from using wwise and am a bit new to Fmod so was looking a for a way to emulate the parenting hierarchy for sound properties (volume/sends/panning) and thought nested events might do the trick. I’m having trouble actually playing back and accessing nested events from unity. Nested events do not appear in the studio event emtter drop down, and pasting the event path just comes up with ‘event not found’. What is it I’m doing wrong or am I fundamentally misunderstanding how nested events work? Thanks in advance.
There is some information on Nested Events in our docs that might be helpful too:
https://www.fmod.com/resources/documentation-studio?version=2.0&page=organizing-the-project.html#nested-events
If an Event doesn’t appear in the Unity Event Browser or the Studio Event Emitter drop down it could be caused by the Event not being assigned to a Bank in Studio.
Those nested events cannot be used outside of the parent event, you can create a separate event and reference it in another event but by adding an Event Instrument to an event it creates an internal event that can only route through the parent.
few years after but…have you notice by any chance if nested event don’t paly in unity? I am using a simple Studio Event Emitter and if I make it play a normal event it plays, but not if I set it to the nested event. Really not sure why, any ideas?
Are you getting any errors or warnings in the Unity Output Log?
no
could it be something dependent on the size of the event on the timeline?
I managed to make it work again, by not using event instrument and just creating layers of tracks in one new event
It’s difficult to say if you aren’t getting anything in the logs.
Could you try setting the logging level in the FMOD Unity Settings to Level Log and Enable API Error Logging to see if we can get any information on a cause.
