Best Practice to set Event Min Max Distances
How can I set the Min Max Distances of all 3D Events to specific values by default? Is there a global setting?
Unfortunately, there is no default setting. However, I have created a Studio script that can be put into C:\Users\XXX\AppData\Local\FMOD Studio\Scripts which will set the values for all 3D events:
SetDefaultDistances.txt. Just remember to change the extension to .js to use it.
And where is this on Mac, if someone can point me to it, please?
On macOS it should be found here: Macintosh HD > Users > XXX > Library > Application Support > FMOD Studio > Scripts
It sure did :slight_smile: , thank you.
