Blueprint setup for door sounds ?
I have a BP actor “door” where I need to have start sound, movement sound, stop sound and re-trigger sound (when door gets blocked and rolls back, this sound would play).
What would general BP setup look like ?
Would I just make short, non-looping sounds for start and stop and re-trigger sounds and simply let them play till they finish while playing looped movement sound?
How would I stop / cut looping movement sound in BP ? (this way I can use same movement sound for tall doors and for small hatches)
Thanks beforehand
There are a few ways you could set up your doors, it all depends on what is going to fit best with your event/s in FMOD Studio.
Generally you will want to have a FMODAudio Component, this will remove the need to create an instance, that you can then control ( eg. play, stop, set parameter, set property).
