If an instrument is conditionally triggered by a labelled parameter, if I change the label order in the parameter settings, the condition disappears.
EDIT: the bug could be broader than what I tought: after changing labels order, in the sandbox the event still continues to play with previous state parameter. I solved the problem, but I’m not sure if if was by clearing and re-inputing conditions, or by restarting FMOD.
This is definitely a bug, thanks for bringing this to our attention. I’ll pass this onto our development team.
Hi! Are there any updates to that trouble? I’m having the same issue, the target and trigger disappear when I press play.
This should have been resolved in 2.01.08+. Can you confirm you have updated to the latest version?
