Instrument trigger conditions won't work when added to multiple instruments
We ran into trigger condition issues in 02.03.05 as well as 02.03.08.
We managed to isolate the problem in a separate project and linked the video below.
The problem:
When assigning a labeled parameter as a condition on multiple nested events at the same time, it does not register some of them on playback. You have to manually delete the condition and add it individually again for it to work properly.
In the video below I show the problem isolated in a test project. We can easily work around it by adding the conditions one by one, but it would be great if it can be addressed in future FMOD versions.
If there are more questions, please let me know.
Video showcasing the problem: https://youtu.be/iNoBMO5RdiA
This seems to be the same problem: Bug Report: Parameter Conditions Multi Edit Fails
You are correct: This is the known issue described in the thread you linked. It’s already in our bug tracker, and will be fixed in an upcoming release of FMOD Studio.
In the mean time, I can only recommend avoiding bulk editing labelled trigger conditions, or using the workaround of deselecting and reselecting the event after adding labelled parameter trigger conditions but before bulk editing them.
Thank you for your quick response. We look forward to the update.
