Build stuck on "Importing Assets"
Hi there,
I am having issue building my unity project either for Mac or WebGL. Each time it always get stuck on “importing assets” with no error messages. Then Unity will crash, and I will have to force close the application from Mac’s Task Manager as Unity stop responding.
The project itself is 8.53 GB, and no gigantic assets as far as I can tell. I have implemented audio via FMOD (it’s my first time using FMOD so I am wondering if there’s some setting that is off).
Unity: 2022.3.117f1
FMOD: 2.02.21
MacOS: Big Sur 11.7.2
Would highly appreciate if anyone can point directions. Many thanks.
Can you check the Unity editor logs for any errors, for Mac the default location is ~/.config/unity3d/Editor.log, otherwise from the crash logs.
Same issue here, similar version.
Not errors at console nor log.
Turns out, it has to do with the HDRP tree assets I was using. Once I uninstall the package, everything was fine.
