Assets/Plugins/FMOD/BankRefAttribute.cs(5,37): error CS0246: The type or namespace name `PropertyAttribute’ could not be found. Are you missing an assembly reference?
Assets/Plugins/FMOD/FMOD_Listener.cs(5,30): error CS0246: The type or namespace name `MonoBehaviour’ could not be found. Are you missing an assembly reference?
Assets/Plugins/FMOD/RuntimeManager.cs(370,91): error CS0246: The type or namespace name `Transform’ could not be found. Are you missing an assembly reference?
It’s like fmod cant find unity anymore?
Using unity 5.6.3f1 and fmod 1.10.00
Building any other platform works.
Tried re-installing unity, rebooting, re-importing plugin. rebuild fmod project nothing works, tried it on a new blank project as well.
Something definitely isn’t right, before re-importing the plugin can you try deleting the Assets/Plugins/FMOD folder. If that doesn’t work I would suggest downloading the plugin again.
Removing Assets/Plugins/FMOD and redownloading and re-importing did not fix the problem.
any reference to unityEngine seams to fail
Assets/Plugins/FMOD/StudioParameterTrigger.cs(64,30): error CS0246: The type or namespace name `Collider2D’ could not be found. Are you missing an assembly reference?
stopped working after the first build of a different platform.
built win worked.
switched to mac, built mac, built worked.
switched back to windows, build cant find unityEngine.
switching around, reinstalling unity, moving project, all fails now.
